I run my own pc as a power user but also have an other half where things have to be a bit simpler as she is unfamiliar with cli’s and setting stuff like this up. Taking both types of users into account here is a nice list of my top missing features meant as constructive criticism
Mount a revision as a virtual file system. This would greatly improve the user friendliness of the restore process and facilitate easy searching within a revision.
Provide a search box with filtering to search for files/folders inside all revisions simultaneously or inside a date range of revisions. I can use the cli and have it spit out a long text file containing all file names in all revisions. But if you are limited to the GUI, you would be in for a long ride of clicking your way through revisions.
Have the option to execute missed scheduled jobs due the computer being OFF or otherwise prevented from starting a job at the scheduled time. Sure you can schedule backups often enough to side-step the matter but I schedule prune and check jobs less often. So they are most susceptible to being missed.
Start a job if a certain drive gets plugged (external drive) in or mounted (Veracrypt volume). Additionally, there should be an option only to start the job if it has missed a scheduled time.
It would be okay to having to mount it to the same drive letter but it would be nice if it can be identified using a config file present on the drive or volume. -
Implement a backup restore GUI button for config export and import for easy migration to another computer.
That’s what I came up with for now. Any takers:)?
