Duplicacy looks really robust, and am looking at moving to it for my part of my backup strategy.
I found this post and this post that didn’t quite answer my question.
For context: I’m running MinIO in a Docker container on a Synology NAS. I also have it running on TrueNAS on a different server.
I downloaded the duplicacy gui, and was able to do a small backup to an external drive. I was unable to configure my minio servers as storage.
I switched to the cli and used the -d option as suggested, but it didn’t really add any helpful information.
(base) ➜ Databases duplicacy -d init dbtest minios://none@10.0.0.35/bucket/dbtest
Reading the environment variable DUPLICACY_S3_ID
Enter S3 Access Key ID:<deleted>
Reading the environment variable DUPLICACY_S3_SECRET
Enter S3 Secret Access Key:<deleted>
Failed to download the configuration file from the storage: RequestError: send request failed
caused by: Head https://10.0.0.35/bucket/dbtest/config: x509: cannot validate certificate for 10.0.0.35 because it doesn't contain any IP SANs
(base) ➜ Databases
If I try the server on my other computer, the error is the same, save for the IP address being different.
I’ve also tried different values for the region, but as far as I know, MinIO doesn’t have regions in its configuration.
I’ve also tried using minio, instead of minios.
(base) ➜ Databases duplicacy -d init dbtest minio://none@10.0.0.3/bucket/dbtest
Enter S3 Access Key ID: <deleted>
Enter S3 Secret Access Key: <deleted>
Failed to download the configuration file from the storage: Failed to parse the config file: invalid character '<' looking for beginning of value
Using minio and appending the port number (9000) gives this error:
Failed to download the configuration file from the storage: BadRequest: Bad Request
status code: 400, request id: , host id:
Both of these servers work with Arq using https and the port number.
Edit to add: I can use the interface for both MinIO installs from my browser with https without certificate (or other) errors.
Thanks for any insight!
macOS 11.6 (20G165), duplicacy cli 2.1.2 (2e5cbc), duplicacy web edition 1.5.0
Synology: MinIO: VERSION 2020-03-19T21:49:00Z PLATFORM Host: minio | OS: linux | Arch: amd64 RUNTIME Version: go1.13.8 | CPUs: 4
TrueNAS: VERSION 2021-04-06T23:11:00Z PLATFORM Host: truenas.local | OS: freebsd | Arch: amd64 RUNTIME Version: go1.16.4 | CPUs: 4
