I just had a case where I had no internet for a while. I restarted my computer and when the Web-GUI openend it looked completely meesed up. There were no graphics. The layout is non existent, there are no buttons to start backups, add backup, schedules or change anything. I do a local backup and it appers that the schedule for the local back was still running which is good. However the worse was that it is not possible to restore anything. The restore fields are not accessible. This is not good if you are working offline and need to restore a file.
I always thought this programm was an “offline” product and I was not aware that you need an active internet connection to use it. It is not mentioned on the web site or documentation anywhere.
Now that I said this, I do hope it is just some setting I missed or an user error so I can get Duplicacy to work.
Is there a workaround to make it work offline?
Thanks
