Maybe I am mistaken but i’ve observed a few conditions:
ERROR when File should be accessible but is not
WARN when a file simply is not accessible
And backup completes with snapshot when WARN condition occurs…  See the below from my logs
01:25:27.848    Failed to read the symlink: readlink C:\Users\####\.duplicacy\shadow\Users\####\Application Data: Access is denied.
01:25:27.849    Failed to read the symlink: readlink C:\Users\####\.duplicacy\shadow\Users\###\Cookies: Access is denied.
01:25:27.849    Failed to read the symlink: readlink C:\Users\####\.duplicacy\shadow\Users\####\Local Settings: Access is denied.
01:25:27.850    Failed to read the symlink: readlink C:\Users\####\.duplicacy\shadow\Users\####\My Documents: Access is denied.
01:25:27.850    Failed to read the symlink: readlink C:\Users\####\.duplicacy\shadow\Users\###\NetHood: Access is denied.
01:25:27.850    Failed to read the symlink: readlink C:\Users\####\.duplicacy\shadow\Users\####\PrintHood: Access is denied.
01:25:27.851    Failed to read the symlink: readlink C:\Users\####\.duplicacy\shadow\Users\####\Recent: Access is denied.
01:25:27.851    Failed to read the symlink: readlink C:\Users\####\.duplicacy\shadow\Users\####\SendTo: Access is denied.
01:25:27.851    Failed to read the symlink: readlink C:\Users\####\.duplicacy\shadow\Users\####\Start Menu: Access is denied.
01:25:27.852    Failed to read the symlink: readlink C:\Users\####\.duplicacy\shadow\Users\####\Templates: Access is denied.
01:25:29.635    Failed to read the symlink AppData/Local/Packages/#########_b6e429xa66pga/LocalCache: Unhandled reparse point type 80000018
01:25:29.863    Failed to read the symlink AppData/Local/Packages/Microsoft.Microsoft3DViewer_8wekyb3d8bbwe/LocalCache: Unhandled reparse point type 80000018
<snip>
1:29:08.712    Backup for C:\Users\#### at revision 41 completed
01:29:08.712    Files: 64863 total, 38,638M bytes; 6544 new, 1,690M bytes
01:29:08.712    File chunks: 8074 total, 40,886M bytes; 114 new, 663,321K bytes, 322,280K bytes uploaded
01:29:08.712    Metadata chunks: 9 total, 21,866K bytes; 9 new, 21,866K bytes, 7,410K bytes uploaded
01:29:08.712    All chunks: 8083 total, 40,907M bytes; 123 new, 685,188K bytes, 329,690K bytes uploaded
01:29:08.712    Total running time: 00:03:47
01:29:08.712    12 files were not included due to access errors
01:29:08.789    The shadow copy has been successfully deleted
Now, when I look at those specifically, they all are not really an issue for me and they should be excluded;however , it does tell me that there are “Failed” conditions that the backup engine accepts as “WARN” conditions in the logs and completes the backup.
or am I missing something obvious?
