Is there a way to configure a storage using a Storj bucket in the web-UI? I don’t see a dedicated “Storj” provider under S3, and fiddling with the endpoint hasn’t worked for me…
P.S. Duplicacy Web 1.6.3 using Duplicacy CLI 3.0.1
If I read Duplicacy does not fetch updated CLI engine correctly, this will come in a new Duplicacy Web release.
I use Storj as a backend in the following way:
Configure a storage bucket
Connect Rclone to connect to the bucket using an access grant
Mount the Rclone remote
Run the Duplicacy image in Docker, pointing a storage path in the image to the Rclone mount point.
In the Duplicacy UI, all I do is add a disk location, pointing to the container path that connects to the Rclone mount point.
Everything works ok except Prune. All I did to make Prune work? Add an -exclusive flag and ensure that no other backup process is running concurrently. It’s because a particular command isn’t implemented well in Storj yet.
FYI I tried to make the Storj gateway work out (it’s a Storj uplink and a Minio instance bundled together). It has way too much network overhead. I think it’s intended for a fatter outbound pipe than I’ve got currently.
I also tried to make S3 work; it just isn’t compatible in the way Storj has implemented it. Plus it costs more.
Thanks for tips! Hopefully Storj will be supported natively soon.
It’s already supported:
Using the CLI it is, but not yet through the web-UI.
I would strongly suggest using Rclone serve instead of the mount: This removes a whole host of potential issues related to FUSE and local filesystem, and improves determinism.
That said - maybe adding “rclone remote” would not be a bad idea? This will immediately make all those storages accessible in one go.
Is this planned?
Talking of this… Long ago I noticed Rclone has a serve restic
. I haven’t looked too much into Restic, but gather Duplicacy was loosely inspired by some of its features(?). I know Kopia can use Rclone directly as well.
I have to wonder, if leveraging Rclone and/or a REST API is the way forward in supporting new storage backends - perhaps even replacing some tricky ones (OneDrive) - since Rclone’s codebase would be more robust and more thoroughly tested.
Hoping this is added to the web-UI. That said, is there a way to leverage your container and manually add storj via the CLI but have it reflect in the web-UI after being added?
I tried something to the effect of /config/bin/duplicacy_linux_x64_3.1.0 add -e -copy Local -bit-identical -key /config/duplicacy-priv.pem Storj Media storj://xxxxxxxxxxxxxxxxxxxxxxxxxx@us1.storj.io:7777/Duplicacy
but I don’t think I’m doing it properly. It said Repository has not been initialized
I don’t think so. The configuration files for CLI are [over]written by the GUI.
You can start backing up via S3 gateway, and then when duplicacy GUI catches up—switch to native.
Got it, I’ll check that out.
