Hello again!
Small question…
I have read through this: Init command details
Specifically I would like to ask about the key iterations value.
The
-iterationsoption specifies how many iterations are used to generate the key that encrypts theconfigfile from the storage password.
If I had started a backup, and then later adjusted this value “key_iterations” in the duplicacy.json, what is the consequence of this? Nothing if it’s just for the config file??
Thank you. I just want to ensure my data is safe. I increased the key iterations value because I thought it would increase security.
