https://acrosync.com/duplicacy-web/duplicacy_web_installer_win64_1.6.3.exe
https://acrosync.com/duplicacy-web/duplicacy_web_osx_arm64_1.6.3.dmg
https://acrosync.com/duplicacy-web/duplicacy_web_osx_x64_1.6.3.dmg
https://acrosync.com/duplicacy-web/duplicacy_web_linux_x64_1.6.3
https://acrosync.com/duplicacy-web/duplicacy_web_linux_arm64_1.6.3
https://acrosync.com/duplicacy-web/duplicacy_web_linux_arm_1.6.3
https://acrosync.com/duplicacy-web/duplicacy_web_freebsd_x64_1.6.3
QNAP packages:
https://acrosync.com/duplicacy-web/duplicacy_web_qnap_arm_64_1.6.3.qpkg
https://acrosync.com/duplicacy-web/duplicacy_web_qnap_arm_x31_1.6.3.qpkg
https://acrosync.com/duplicacy-web/duplicacy_web_qnap_arm_x41_1.6.3.qpkg
https://acrosync.com/duplicacy-web/duplicacy_web_qnap_x86_1.6.3.qpkg
https://acrosync.com/duplicacy-web/duplicacy_web_qnap_x86_64_1.6.3.qpkg
Synology packages:
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_alpine_1.6.3.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_apollolake_1.6.3.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_armada370_1.6.3.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_armadaxp_1.6.3.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_avoton_1.6.3.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_braswell_1.6.3.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_broadwell_1.6.3.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_broadwellnk_1.6.3.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_bromolow_1.6.3.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_cedarview_1.6.3.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_denverton_1.6.3.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_geminilake_1.6.3.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_grantley_1.6.3.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_rtd1296_1.6.3.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_v1000_1.6.3.spk
1.6.3 Changes:
- Call Sync() before Close() when updating the configure file duplicacy.json
 - Add a storage tab for IDrive e2
1.6.2 Changes:
- Fixed a bug that made the âStart on loginâ option not persistent after restart on Windows
 - Synology packages can now be upgraded without overwriting existing configurations
1.6.1 Changes:
- Fixed a bug that caused some folders to disappear when a sibling folder is collapsed in file/folder selection dialog
 - Add -background as the startup option when Start on Logon is enabled
1.6.0 Changes:
- Fixed a coloring bug in the storage graph when there are more than 15 backup ids
1.5.3 Changes:
- Restore can now continue to run in the background after the Restore page is closed
 - Pass storage credentials to the CLI in keyring/keychain if
safe_credentialsis set totrueinsettings.json[1] - In file/directory selection dialogs, directories can now be expanded or collapsed with double-clicks
 - Fixed an initialization failure bug when running multiple jobs in parallel
 - Fixed a bug that causes schedules to run repeatedly between 1am to 2am on the starting day of daylight saving time [2]
 - Fix a bug that causes a trial license to become invalid after a docker restart
[1] By default storage credentials needed by the CLI are passed as environment variables. If you create a new key in settings.json named safe_credentials and set it to true, then storage credentials will be saved in keyring/keychain which is visible to the CLI.
[2] Youâll be affected by this bug if you have a schedule to be run between 2am (inclusive) and 3am on this coming March 13th. If you donât want to upgrade, a workaround is to temporarily change the run time of the schedule to before 2am or after 3am.
