-vss not working with Catalina
Hi, I upgraded to Catalina yesterday and since then backups have been failing with this:
Running backup command from /Users/vito/.duplicacy-web/repositories/localhost/0 to back up /Users/vito
Options: [-log backup -storage local -threads 1 -vss -stats]
2019-10-09 02:00:01.843 INFO REPOSITORY_SET Repository set to /Users/vito
2019-10-09 02:00:01.843 INFO STORAGE_SET Storage set to /Volumes/Backup/duplicacy
2019-10-09 02:00:15.621 INFO BACKUP_START Last backup at revision 8774 found
2019-10-09 02:00:18.982 ERROR VSS_CREATE Error while mounting snapshot: %!(EXTRA *exec.ExitError=exit status 66)
How can I fix? Thanks!
I logged in on the website and it looks like I can’t submit tickets even though the license is still active?
Check the error in the code here duplicacy/duplicacy_shadowcopy_darwin.go at master Ā· gilbertchen/duplicacy Ā· GitHub it seems that there may be a problem with the names of the snapshots. Snapshots are created with a name having the ā€˜.local’ suffix from what I can see:
āžœ tmutil listlocalsnapshots /
Snapshots for volume group containing disk /:
com.apple.TimeMachine.2019-10-09-175949.local
com.apple.TimeMachine.2019-10-09-180014.local
But the command duplicacy uses to mount the snapshot doesn’t include that suffix
"/sbin/mount", "-t", "apfs", "-o", "nobrowse,-r,-s=com.apple.TimeMachine."+snapshotDate, "/", snapshotPath)
Am I reading this right? In fact I tried mounting a snapshot manually the same way and I get the same code 66. Please help, I don’t want to be without backups.
Can you post a screenshot of your backup schedule? I’m curious if the -vss option gets added automatically or if you added it.
If you added it, then one workaround might be to simply remove it.
I added it and for now I am backing up without that option, although it seems a lot slower. It looks like it’s not just me VSS not working on macOS Catalina Ā· Issue #576 Ā· gilbertchen/duplicacy Ā· GitHub
Yeah, it doesn’t seem user-specific. Removing -vss is just a workaround if you don’t want to be without backups until this is addressed.
I’m not sure why it would be slower. If anything, now duplicacy shouldn’t have to wait for files with exclusive locks (though might not be able to backup such files without -vss).
Reference: backup command details, -vss
It looks like adding the .local suffix should fix it, but I haven’t upgraded to Catalina so can’t really test the fix. Can anyone check if this fix works?
There is also the problem of how to detect the macOS version in order to decide whether or not to add the .local suffix.
The ā€œrightā€ approach would be to query the system profiler or ioregistry, but you can also run sw_vers and parse output, or read kern.osversion from sysctl — the 19 followed by letter and build number is Catalina.
However I’m wondering if there is better way to do the right thing without changing behavior based on version
I imagine one way of doing it would be to run
$ tmutil listlocalsnapshots /
com.apple.TimeMachine.2019-10-14-180021.local
and grep for the date we want (although I have no idea how portable that would be).
@gchen I can definitely test, and implement a version check using one of the methods suggested by saspus or timnn.
Do you have a preference?
I created a PR that uses tmutil listlocalsnapshots: Bugfix: allow -vss usage on Mac OS Catalina by gboudreau Ā· Pull Request #578 Ā· gilbertchen/duplicacy Ā· GitHub
Can easily be changed to another technique to detect the correct snapshot name to use.
I think there is a bigger issue here.
Right now Duplicacy is for some reason asking Time Machine to create snapshots for it. Format and naming of these snapshots are Time Machine implementation details. Duplicacy shall not rely on that. Instead, it shall create snapshots using filesystem API directly – see man fs_snapshot_create
If I remember correctly, the issue with using fs_snapshot_create directly is that it requires a special entitlement from Apple. This can be requested from Apple, but it also requires additional review.
Excellent point. @gchen should reach out to Apple. From what I understand from quick googling it seems the entitlement is being granted to backup applications that can demonstrate that they won’t clog up the drive with snapshots over time. Duplicacy creates a snapshot for a duration of a backup and should delete it afterwards – in this case it should be easy to get an approval; (Weren’t Carbon copy cloner and super duper granted one?)
It looks like this has recurred again, with the recent MacOS Update (10.15.4) :frowning:
I finally updated to Catalina some weeks ago and all was fine with Duplicacy (duplicacy-web 1.2.1 + duplicacy_osx_x64_2.4.1), including the -VSS. A MacOS update came through the other day (27-Mar) and my -VSS backups have been failing ever since.
Brian
Works for me.
me@obsidian ~ % duplicacy backup -vss
Running script /Users/alex/.duplicacy/scripts/pre-backup
Storage set to sftp://me@redacted//Backups/duplicacy
Last backup at revision 1676 found
Shadow copy created and mounted at /tmp/snp_043824422
Backup for /Users/me at revision 1677 completed
4 files were not included due to access errors
Shadow copy unmounted and deleted at /tmp/snp_043824422
What errors are you seeing? Anything in the console?
The log when it was failing (one of many - it was like this for some days):
Running backup command from /Users/brian/.duplicacy-web/repositories/localhost/11 to back up /Users
Options: [-log backup -storage MacBook-Duplicacy-4T -vss -vss-timeout 200 -stats]
2020-04-03 00:30:01.080 INFO REPOSITORY_SET Repository set to /Users
2020-04-03 00:30:01.081 INFO STORAGE_SET Storage set to /Volumes/Duplicacy-4TB/Duplicacy
2020-04-03 00:30:02.045 INFO BACKUP_START Last backup at revision 138 found
2020-04-03 00:30:02.612 ERROR VSS_CREATE Error while mounting snapshot: exit status 77
After I removed the VSS option:
Options: [-log backup -storage MacBook-Duplicacy-4T -stats]
2020-04-03 00:30:56.681 INFO REPOSITORY_SET Repository set to /Users
2020-04-03 00:30:56.681 INFO STORAGE_SET Storage set to /Volumes/Duplicacy-4TB/Duplicacy
2020-04-03 00:30:57.053 INFO BACKUP_START Last backup at revision 138 found
2020-04-03 00:30:57.053 INFO BACKUP_INDEXING Indexing /Users
2020-04-03 00:30:57.053 INFO SNAPSHOT_FILTER Parsing filter file /Users/brian/.duplicacy-web/repositories/localhost/11/.duplicacy/filters
2020-04-03 00:30:57.054 INFO SNAPSHOT_FILTER Loaded 43 include/exclude pattern(s)
… and so on
A couple of points:
  • I realised that I hadn’t mentioned the MacOS version, so I edited the post to include that. I may not have done that before you read it. Are you on MacOS 10.15.4?
  • Looking at your log, I see both that you don’t have a -vss-timeout option set and that you’re running directly from the command line (I’m using the web edition). I’ll try both those tomorrow morning when I’m more awake.
I’ve just tried with duplciacy-web, same story, works fine.
Duplicacy simply calls mount on a snapshot it just created; I’m not sure what does error code 77 mean
       // Mount snapshot as readonly and hide from GUI i.e. Finder
        _, err = CommandWithTimeout(timeoutInSeconds,
                "/sbin/mount", "-t", "apfs", "-o", "nobrowse,-r,-s="+snapshotName, "/", snapshotPath)
        if err != nil {
                LOG_ERROR("VSS_CREATE", "Error while mounting snapshot: %v", err)
                return top
Check the following:
  • Do you have access to /tmp folder?
  • Run tmutil snapshot. Does it succeed? It would return timestamp for the snapshot.
  • List snapshots tmutil listlocalsnapshots /. Do you see your snapshot from above there?
  • create temp folder mkdir /tmp/test
  • Mount snapshot there: mount -t apfs -o "nobrowse,-r,-s=com.apple.TimeMachine.2020-04-03-201431.local" / /tmp/test. Substitute correct date from above. Does it succeed or you get the same error 77?
  • unmount the snapshot umount /tmp/test
  • delete the snapshot tmutil deletelocalsnapshots 2020-04-03-215916 – put whatever date tmutil snapshot returned above command returned.
Where does it fail?
As a prophylactic I would boot into recovery partition and run first aid on a partition, then on a APFS container and then on a volume. If still fails – I would nuke all local time machine snapshots and try again.
Thanks for such a comprehensive and useful reply. It sent me down a very informative path.
I haven’t solved the issue, but I have a lot more information.
For ease of reading, I’ll summarise what I’ve found here and explain how I got there below that:
  • I’m sure that the problem is a result of the update to MacOS 10.15.4 that was applied (on my machine) on 27th March at 09:50.
  • It doesn’t fail on my machine when Duplicacy is run from the command line, but it does when called from Web Edition.
  • The relevant snapshot is created without issue. The failure occurs on mounting that snapshot in the filesystem.
  • It looks like, when called from Web Edition, the mount attempt is to /private/tmp/snp_nnnnnnn, whereas when run from the command line, the mount occurs on /tmp/snp_nnnnnnn.
  • It appears to me to be a problem with the changes to the Sandbox policies that came with the 10.15.4 update.
What I did to come to those conclusions:
I started out following your suggestions.
  • I tried your list of commands, and everything worked perfectly correctly. No failure at all:-(
  • So I moved on to your prophylactics. Ran First Aid on first the partition, then the container and finally each volume. All perfectly OK. BTW, I don’t think one needs to do the volumes after the container: it looked like First Aid on the container did a tree-walk of all volumes and checked each one out. But I did them separately for completeness.
  • I also did the ā€œdeletelocalsnapshots /ā€ thing. This removed all but one of the snapshots and allowed me to remove the final one separately.
None of that changed things. It still failed with Error 77. Not only that, but, when it fails, it leaves behind the directory of the form /tmp/snp_nnnnnnn in which it fails to mount the snapshot.
Then I tried running from the command line. I did this initially because I wanted to see whether the previous version of Duplicacy, duplicacy_osx_x64_2.4.0 would fail. It didn’t.
Nor did the current version, duplicacy_osx_x64_2.4.1, either. Both ran with -vss as arguments and did the right thing.
So I went back and verified: the Web Edition still fails, on exactly the same backup.
At this point I started digging in the MacOS Console Log (which seems to be more comprehensive than the syslog), re-running Duplicacy with -verbose and even -debug and then comparing the timestamped records in the Console Log with those in the Duplicacy output.
What I observed was:
  • In a successful run, the (significant) Console log entries look like this:
      default 14:16:27.604863+1000    kernel  fs_insert_snapshot_metadata:254: snap_name='com.apple.TimeMachine.2020-04-05-141627.local' snap_xid 8057969 extentref oid 917407 sblock oid 915526
      default 14:16:27.670779+1000    kernel  handle_snapshot_mount:490: mounting snapshot w/snap_xid 8057966 and sblock oid 0xde67a
      default 14:16:27.670804+1000    kernel  handle_mount:329: vol-uuid: 023BA78F-896D-465B-93FC-174A1E95FE94 block size: 4096 block count: 122086923 (unencrypted; flags: 0x1; features: 1.0.12)
      default 14:16:27.671188+1000    kernel  apfs_vfsop_mount:1489: mounted volume: Macintosh HD
  • whereas in a failing one, they look like:
      default 14:43:31.180979+1000    kernel  fs_insert_snapshot_metadata:254: snap_name='com.apple.TimeMachine.2020-04-05-144331.local' snap_xid 8059163 extentref oid 911201 sblock oid 1115909
      error   14:43:31.304968+1000    kernel  Sandbox: mount_apfs(6531) System Policy: deny(1) fs-snapshot-mount /private/tmp/snp_021295157
      default 14:43:31.304981+1000    kernel  apfs_vfsop_mount:1406: handle_*_mount failed, err: 1
      default 14:43:31.304985+1000    kernel  apfs_vfsop_mount:1460: apfs_vfsop_mount failed, err: 1
  • Sometimes, but not every time, the failing one also tries to create a snapshot on volume /Volumes/Recovery, but that fails with the message error: Error Domain=NSPOSIXErrorDomain Code=45 "Operation not supported". I don’t know whether that’s significant or not.
  • Similarly, there is a lot of snapshot cleaning up and filecoordinationd does a lot of arbitration, but I think that’s all just secondary to snapshot creation.
  • What may be more significant is that the Duplicacy output of the successful runs shows that the snapshot is mounted in /tmp/snp_nnnnnnn, where the Console log of the failures shows an attempt to mount in /private/tmp/snp_nnnnnnn.
    • While I know that they are the same directory in practice (/tmp is symlinked to /private/tmp) it’s possible that something at a deeper level treats them separately.
    • It’s also possible that all I’m seeing there is an artefact of the way the different logs are being written:-}
  • I also observed that the VSS Snapshot is actually created (it’s still there afterwards). The error occurs when Duplicacy attempts to mount the snapshot in the temporary directory.
The report of Sandbox and System Policy being invoked sent me looking at extended attributes and into the Sandbox directory (/System/Library/Sandbox). While I don’t pretend to understand the semantics of the *.sb files, what I did observe was that:
  • a number of the most-obviously significant files in the Profiles sub-directory (such as system.sb and application.sb) were updated in that directory on 27th March at 9:50am.
  • The last functional VSS copy from Duplicacy is timestamped at 2020-03-27 09:15 (that particular schedule runs hourly).
  • So the issue definitely started when that update (10.15.4) was applied.
I can supply logs if you’d like to look deeper.
Brian
Fascinating!
First – it just occurred to me that the fact that it works for me is another indirect confirmation of what you suspect: that it may indeed have to do with permissions/policies/security/sandboxing: I have both secure boot and SIP disabled… since forever, and I completely forgot about that.
So, this is our culprit:
I diffed the whole Profiles folder with what I had on another Mac with 10.15.1 and did not see any relevant changes at a first glance.
I have a few ideas to try (will try in the evening)
  1. the duplicacy_web is signed, while the duplicacy CLI is not signed at all. I’m not sure, but maybe it inherits restrictions of a parent process when launched as such:
    me@obsidian ~ % codesign --verify --verbose ~/.duplicacy-web/bin/duplicacy_osx_x64_2.4.1
    /Users/me/.duplicacy-web/bin/duplicacy_osx_x64_2.4.1: code object is not signed at all
    In architecture: x86_64
    me@obsidian ~ % codesign --verify --verbose /Applications/Duplicacy\ Web\ Edition.app/
    /Applications/Duplicacy Web Edition.app/: valid on disk
    /Applications/Duplicacy Web Edition.app/: satisfies its Designated Requirement
    Wondering what will happen if we sign the Duplicacy command line with default entitlements – will it start failing? (I can try that tomorrow only – I cannot turn back security on my Mac to test this, I’ll need to find another one or configure VM). If that is the case gchen will need to adjust entitlements.
  2. Assuming the issue is with restrictions on access to filesystem snapshots (and it is indeed quite sensitive from security perspective access): Will the behavior change if you add Duplicacy Web to System Preferences -> Security and Privacy -> Full Disk Access?
  3. In case the issue with the mount point (as opposed to access to the snaphot in the first place – Instead of using /private/tmp/ or /tmp why not do it right and use mktemp to generate temp file path (it will end up in /var/folders/ and should be fully accessible`). (If I find a place to run macOS with full security on I’ll try that later – or you can try that. But I suspect the item 2 above should help)
Brilliant!! That fixed it :smiley:
A simple change to the Doco, or, in the longer term, a change to the installer to prompt the Preferences change (if that is possible).
What’s the process to initiate those?
That’s the problem with ā€œtemporarilyā€ lifting security constraints - we forget that we’ve done it :roll_eyes:.
Thanks again!
Brian
