Duplicacy Web Edition 1.7.2 releases
https://acrosync.com/duplicacy-web/duplicacy_web_installer_win64_1.7.2.exe
https://acrosync.com/duplicacy-web/duplicacy_web_osx_arm64_1.7.2.dmg
https://acrosync.com/duplicacy-web/duplicacy_web_osx_x64_1.7.2.dmg
https://acrosync.com/duplicacy-web/duplicacy_web_linux_x64_1.7.2
https://acrosync.com/duplicacy-web/duplicacy_web_linux_arm64_1.7.2
https://acrosync.com/duplicacy-web/duplicacy_web_linux_arm_1.7.2
https://acrosync.com/duplicacy-web/duplicacy_web_freebsd_x64_1.7.2
QNAP packages:
https://acrosync.com/duplicacy-web/duplicacy_web_qnap_arm_64_1.7.2.qpkg
https://acrosync.com/duplicacy-web/duplicacy_web_qnap_arm_x31_1.7.2.qpkg
https://acrosync.com/duplicacy-web/duplicacy_web_qnap_arm_x41_1.7.2.qpkg
https://acrosync.com/duplicacy-web/duplicacy_web_qnap_x86_1.7.2.qpkg
https://acrosync.com/duplicacy-web/duplicacy_web_qnap_x86_64_1.7.2.qpkg
Synology packages:
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_alpine_1.7.2.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_apollolake_1.7.2.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_armada370_1.7.2.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_armadaxp_1.7.2.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_avoton_1.7.2.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_braswell_1.7.2.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_broadwell_1.7.2.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_broadwellnk_1.7.2.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_bromolow_1.7.2.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_cedarview_1.7.2.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_denverton_1.7.2.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_geminilake_1.7.2.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_grantley_1.7.2.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_rtd1296_1.7.2.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.0_v1000_1.7.2.spk
https://acrosync.com/duplicacy-web/duplicacy_web_dsm7.1_r1000_1.7.2.spk
1.7.2 changes:
  • Fixed a bug that caused the activity graph to go blank when there are multiple backups with the same source and storage
1.7.1 changes (Windows only):
  • Fixed a bug that caused the program to crash when installed as a Windows service
1.7.0 changes:
  • Use long-lived refresh token for Dropbox backend
  • Add support for Storj
  • Support WebDAV over http (by setting the server to http://server:port)
  • Improve the reliability of the licensing system
  • Add a 15 second timeout to SMTP connections to the sever when sending or testing email
  • Fix a bug which may cause deadlocks when attempting to stop a running backup job
  • Update schedule stat files atomically so they won’t be corrupted by race conditions
  • Make repositories appear in the same order in storage graphs
  • Better naming for manual backup jobs in the dashboard activity graph
Is this a stable release, or still beta?
Thanks for your good work @gchen :slight_smile: I am happy with my purchase supporting you and the open source project.
Does this update include the change mentioned here? Can't enforce Hostname - #14 by gchen
QNAP package, please.
This is supposed to be a stable release, but if you don’t need any changes immediately (like the Dropbox token fix) then I would suggest waiting a few days before upgrading.
Yes it does (to be clear the hostname check is still there).
Links to QNAP and Synology packages have been added.
Fair enough, I am interested in Storj which is why I asked, I’ll just wait for it to show up on the main downloads page.
Thanks for the work, I was never very confident with the other solution that I used to use to backup my Linux machine, this one has given me no problems at all and the restores are quick.
Will the https://duplicacy.com/latest_web_version URL be updated to point to this version soon?
Yes, in a few days…
What text to use to use to get the docker image in a Portainer stack?
Is anything holding this up at this point? I’d like to start copying my data up to Storj as soon as possible.
Thank you.
Updated the release to 1.7.2 to fix a bug in the activity graph: GUI Activities pane is empty?
