There will be a proper topic for web, but currently we’re just collecting the questions and this ad-hoc post should do for now.
I forgot the master password. How can I reset it?
First edit ~/.duplicacy-web/duplicacy.json
to remove the encryption_data
key. Then remove all storages. Then recreate storages with the same names. Backups and schedules shouldn’t be affected.
Any way to remove the administration password once set?
You can edit ~/.duplicacy-web/duplicacy.json
to remove the administration_token
key.
Configure number of threads in web-ui
See
Will the web version import backup jobs and settings from the GUI version?
No, settings will not be imported from the GUI version.
You only need to set them up again once, as the storage is 100% compatible between all versions (web, gui and cli) and you can resume backup jobs as if nothing was changed. All you have to do is point to your existing repository, use the same repository ID, point to the same storage and you’re finished.
See: Web-ui on Debian
Fixed chunk sizes (eg. for backing up Virtual Machines)
The Web UI doesn’t support creating a fixed-size chunk storage yet. For now, you can use the CLI to create such a storage and then add it in the Web UI.
See Set up fixed chunk sizes with Web UI
Disable autoupdate of CLI engine
How to run post-script
See GUI won't run post-scripts
